주요 콘텐츠로 건너뛰기
Apple의 ARM 기반 M1 SoC(8코어 CPU 및 최대 8코어 GPU 탑재)를 탑재한 최초의 13인치 MacBook Air에 대한 수리 안내서, 지원 및 문제 해결 정보입니다. 2020년 11월에 출시되었으며 모델 번호 A2337 또는 EMC 3598로 식별됩니다.
Anyone has the 820-02016-A boardview file please?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 1개
가장 유용한 답변
If you're looking for MacBook boardviews, my go to is the Badcaps forum. I think this post includes files which will work with openboardview software, but don't recall for certain. Definitely will work if you have access to to Flex BV, which is excellent. But paid software.
이 답변이 도움이 되었나요?
점수 4
댓글 4개:
Thank you ,, already tried it but file is not working in Canada
@iphix what does not work in Canada? The download? The boardview?
The boardview!
I think it’s because the file is .BVR not .brd
@iphix if you're using openboardview, check and make sure you're using the latest version. You might have to download it from the GitHub. I know .bvr support on open boardview is relatively new. I just tested this on my personal machine with openboardview and works perfectly, but you need at least version 9.0 for the file to be supported. This is not linked on the obv homepage, you have to go to their Github repository and download there.
댓글 달기
답변을 추가하세요
Justin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 23
전체 시간: 1,788
