I loose power when accelerating and sometimes when in traffic
Intermittent stalling immediately after starting or punching gas. Sometimes also in traffic. I have tried changing the CVT, testing sensors, What might be the issue?
좋은 질문입니까?
좋은 질문입니까?
Sounds like a fuel injector issue. Could also be a vacuum leak.
이 답변이 도움이 되었나요?
I have to check this...But how would I check a vacuum leak ?
That is difficult unless it is a big leak and you can hear it. Disconnecting or pinching off vacuum lines might give a clue, but that involves much understanding of what you are affecting. My bet is on the injectors.
Hi mate. Did you fix your problem?
What if your throttle was clogged?
이 답변이 도움이 되었나요?
I've fixed a clogged catalytic converter that did something like this. I drilled a 3/8" hole in it.
might be fuel filter also that need to be cleaned or replaced..
지난 24시간: 0
지난 7일: 11
지난 30일: 25
전체 시간: 660
