주요 콘텐츠로 건너뛰기
모델 번호 A1238 / 80, 120, 또는160GB 하드 드라이브 / 검정색 또는 은색 금속 외형
904 질문 전체 보기
How do I unlock my iPod Classic?
I have an 80 gb i pod classic but its locked
Update
I have an 80 gb i pod classic black color but its locked.. how to unlocked ...plz help
Rgds,
SAM
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 20
댓글 4개
nice one thank you
On my Ipod 360GB I turn the "hold" button to the off position and it still shows that my Ipod is locked...I have tried all of these suggestions and nothing seems to be working. I just now restored the Ipod but I cant select a language because even though the hold button is not on locked, the Ipod is still locked and will not allow me to use any of the buttons....Any suggestions?
I forgot my combination for my ipod classic 160gb screen lock. How do i reset my combination with out a computer
I have the exact same problem as Chrissy. iPod 80GB model A1136.
댓글 달기
답변 5개
선택된 답변
According to Apples support links you need to hook it up to the computer that it was set up on in order to unlock it. If you no longer have that computer you will need to reset up and restore the iPod from your current mac.
Take care
해당 답변은 도움이 되었습니까?
점수 12
댓글 5개:
thank you apple for your help
dont have a mac,I have a PC
Then use your PC. It works the same.
I no longer have the same computer & the I pod had all of my music on it unlike my I phone which I could not sync the iPods music to.
Yeah there is a program that I used forever ago like 2009 called ipod ripper. Looked it up and still exists, It auto removed DRM, and made it so you could upload files you downloaded from friends computers and sync it to your to your itunes. It even cleans up my Itunes and fills in missing album work https://download.cnet.com/s/ipod-ripper/
댓글 달기
Toggle the "Hold" switch. Move the switch from "Off" to "Hold" and back to "Off" again.
Press and hold the "Menu" and "Select" buttons until the Apple logo appears. This may take up to 10 seconds, so be patient.
Release the buttons one the Apple logo appears and allow your iPod Classic to restart
Read more: How to Unfreeze an iPod Classic | eHow.com http://www.ehow.com/how_5043864_unfreeze...
해당 답변은 도움이 되었습니까?
점수 12
댓글 4개:
he means the lock button on the top let corner
What do you mean by "hold" switch? Is that the home button on the front? So sorry to ask these questions
Thank you! Worked like charm!
Yep it worked Thanks
댓글 달기
Just use a computer download itunes,and make a apple account,its free,plug it to computer,and do a restore,and after u get music and all back on it like u want,plug to computer every now and then ,do a backup,and all,also it will have new firmware updates for your device,goodluck
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
댓글 달기
alquien sabe hacer q mi ipod funcine si se quedpp frizzado no se apaga ni hace nada
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Dejalo que se agote la batería, luego lo puedes cargar y funcinará perfectamente, me sucedió un par de veces...
How to reset code for 80gd ipod the black one
댓글 달기
I have ipod 160gb model 1238 i forgot my combination code.
It cant connect now to the
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
william 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 5
7일 전: 31
30일 전: 115
전체 시간: 103,480
