In its first year in production, the Santa Fe was offered with one of two engine and transmission combinations.
In North America, a fuel-efficient 2.4 L four-cylinder engine was standard equipment and could be mated with either a 5-speed manual or a 4-speed automatic.
이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 2개:
Danny, are there any trouble codes showing on the OBD-II diagnostic port? You'll need a scanner to read them on most cars, but they may give you a clue where to look for the problem.
With very little info given, there are many things to consider; incorrect/incomplete wiring, fuel or ingition issue, factory antitheft system preventing enigne running, etc.
Jerry Wheeler 의
F Dryer 의
