Wire broke. Can it be replaced?
Wire inside broke. Can it be replaced?
좋은 질문입니까?
Broken wires from Ionic Breeze (3 images)
Can the wire be simply soldered back together ?
It would be tricky to clamp into place, but it seems like
electrically, this would work, conductivity is the key thing.
So my thought is to snip 1/4" from the end of the wire
and place it VERY VERY close to the broken (two pieces)
then solder them together so that the maximum size
increase would be just two wires; that little bead would
be able to navigate over the spliced area if you were
very careful sliding it ( 2 of them) as you let gravity
work on the slide(s). cleaning them. Be sure to see the
three images in this post.
이 답변이 도움이 되었나요?
For ionic breeze model number S1730 if the cable broke can it be replacement. If yes where could I buy it ,
Alice
이 답변이 도움이 되었나요?
I read on a different forum that you can purchase the wire here: https://www.sisweb.com/part/W96
I have not tried it.
이 답변이 도움이 되었나요?
지난 24시간: 5
지난 7일: 10
지난 30일: 55
전체 시간: 809
@drpease You’re not giving us much to go on here… Remember, the more information you provide, the easier and better we can help. How to ask a good question on iFixit
Take some good quality and up close pictures of the wire that broke, and update your question with those. Adding images to existing questions
Geir Ove Andersen 의
I believe they are referring to the three (in my case) some units have only two wires running inside the unit from the top PCB to the bottom PCB.
In my unit two of them are broken, can this these wires be repaired? If so, how? Can I find a replacement wire somewhere? Or, can I use some similar wire to repair it?
Hugo 의
@hham If you create your own new question, and you take good quality and up close pictures of the problem, then add the images to the question: Adding images to existing questions, we can help you along :)
Geir Ove Andersen 의
You can buy replacement ionizer wires from the mfg site.
Dwain L. Schmidt 의
