주요 콘텐츠로 건너뛰기
Galaxy S7 Edge는 Samsung의 2016년 주력 휴대폰 Galaxy S7의 곡선형-스크린 버전입니다. 2016년 2월에 발표되었으며 3월 11일에 출시되었습니다. 모델 SM-G935.
369 질문 전체 보기
Lcd swap from one s7 edge to another s7edge
I have 2 galaxy s7 edge g935f, one has a bricked mother board and the other a brocken LCD. I managed to swap the brocken LCD from the bricked mobo one to the one that had the lcd brocken but now the fingerprint doesn't work, and yes it worked fine on the bricked one and yes the brocken screen one had no other issues except for the brocken screen. Any help is appreciated 🙏 thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi @impossibledepth,
You don't say explicitly, but it sounds like you separated the LCD from both phones and swapped it over as shown in the Samsung Galaxy S7 Edge Display Assembly Replacement guide, is that correct? As opposed to moving the good motherboard to the other chassis, right? I'm not sure exactly how Samsung does their fingerprint sensor, but on iPhones they're paired to the motherboard, so I'm going with the idea that they are matched; original home button and original motherboard.
Going on that assumption, then you had to disconnect the home button cable in order to remove the motherboard. Have you double-checked that connector? Unplugged it, cleaned it, and checked for any bent or broken pins on the motherboard and the cable?
If that doesn't do the job, you may have to pull the screen back off and check the flex cable for any damage it might have sustained in the process of removing the display.
You've done all the reset/restart/update kind of software fixes first, though, right?
Let us know what you've tried already and give these ideas some thought and let us know what you come up with and we'll see what else we can figure out to help you.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
1fan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 12
전체 시간: 51
