주요 콘텐츠로 건너뛰기
Apple의 가장 작은 iPhone 14는 9월 9일에 출시되었으며 6.1인치 OLED 디스플레이, 고급 듀얼 12MP 카메라 시스템, 자동 초점 기능이 있는 전면 카메라가 장착되어 있습니다. iPhone 13의 후속 제품입니다.
Why does my iPhone 14 has a smudge on the display?
My Iphone has a smudge which can be visible mostly on grey screens and also can be seen on screenshots. This is weird, since i can see it in a screenshot i think it has some thing to do with software but I'm not sure.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
iOS 16.1.1 just released. Maybe you can try updating?
댓글 달기
답변 3개
가장 유용한 답변
Hi
It looks like it could be some form of
discolouration between the layers or the display
If it’s still in warranty it might be worth a shot taking it to apple to get it fixed under warranty however if it isn’t available you could replace the display to fix the issue
Here’s the guide for that
iPhone 14 스크린 교체
However if it appears in a screenshot it is a software issue and could be fixed by restoring the phone or waiting for a software update that fixes it
Hopefully this helps
Any questions please ask
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
If it appears in a screenshot than it is probably not a issue for the screen.
@thequacker
I mentioned that in a edit :-)
I only realised it was a screen shot after I looked at it several times XD
댓글 달기
Let's retrace:
  • If the issue is on your phone display but doesn't appear on a screenshot it is caused by a stain on the display, such as sauce.
  • If the issue appears on the phone display and screenshot it's a common problem caused by LCD damage or discoloration.
If it's the first issue grab paper towels and thoroughly clean off the display. If it's the second issue you have to replace the display screen either at home or at a repair shop. Just make sure your device still has warranty for qualified repair.
iPhone 14 스크린 교체
이 답변이 도움이 되었나요?
점수 1
댓글 달기
In my own experience, this could be a software bug. Please check on different software to see if the error appears on all applications, if it is always fixed at one point, then this is definitely a hardware error, now you need to bring the phone. this phone to an Apple service center for processing. In case of software failure, you can manually reinstall the new software.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Alon Karaev 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 26
전체 시간: 1,398
