주요 콘텐츠로 건너뛰기
5G 스마트폰이 탑재된 Google Pixel 6a 수리 안내서 및 설명서입니다. 2022년 7월에 출시되었습니다.
replacement screen has a green hue
after replacing the screen with the official replacement from ifixit, I get a green hue when brightness is set to >70%.
I'm not sure what's wrong and I don't see any obvious way of re-calibrating this.
is there a tool or anything I need to run after screen replacement to re-calibrate colors? or is it something I might've done wrong during the installation?
any assistance would be appreciated.
Thanks.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 1개
가장 유용한 답변
You can’t really do anything wrong, must be one of the easiest replacements ever. Disconnect and reconnect the screen making sure the connector is seated properly. If it’s still the same I’d ask for a replacement.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
ok thanks for the sanity check, i'll try re-seating the screen connector later and ask for a replacement if there's no change.
thanks again!
Was it a connector issue, or did you end up getting a replacement? I glued everything back together before realising the issue (hey, it was bright light where I was working!).
Also: Pixel 6a replacement screen has a green hue
댓글 달기
답변을 추가하세요
Hugo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 11
전체 시간: 455
