주요 콘텐츠로 건너뛰기
Apple의 2020년 주력 iPhone은 10월 23일에 6.1" OLED 디스플레이, 듀얼 12MP 카메라 시스템, 그리고 다석 가지 색상으로 출시되었습니다. iPhone 11의 후속 제품입니다.
Is this damaged or can I use it?
I am replacing the display IC from the original screen and scraped away the black layer of adhesive and what could have been the top layer of the chip. Is this still usable after reballing or is it damaged. Very new to this stuff. Thanks!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Hi
When removing chips you will get some minor defects
It your case it looks ok as I can’t see any obvious bits of exposed copper or any chipped or dented bits of the chip
If you want to you could apply a very very thin layer of solder mask where it has been removed (if you do make sure to not get it in the pads,if you do you can carefully scrape it off the pads)to help if you have any on hand
I would put the chip on(after Reballing)and see if it works and if it doesn’t replace it with a new one as small chips like this aren’t expensive to replace:-)
Hopefully this helps
Any questions please ask
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
@hellomacos is correct. Apply solder mask than re-ball the IC as it does not seem damaged.
댓글 달기
I wouldn't take a chance and waste your time the chip is only a couple of dollars so I would just replace it with a new one.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Reball it and try it. Doesn't look too bad to be honest. You've gone this far. Let us know the outcome. Good luck.
댓글 달기
답변을 추가하세요
Salmaan Yehia 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 219
