주요 콘텐츠로 건너뛰기
다양한 주방용품 수리 안내서 및 지원.
81 질문 전체 보기
waffle maker burns the waffles on the outside but doesn't cook them in
Hi i have a waffle maker problem.When i got it i worked fine but now it burns the waffles on the outside and doesn't cook the in the inside and the waffles stick to it
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Vagelis sounds like a heat problem. It gets to hot and burns them in the process. See if you can bring the temp down. If the temp doesn't change then the issue will be with the thermostat or the regulator. The sticking can be caused by the high heat or by the metal plates not having any coating on them. Time to take it apart and to take a good look at it. Post some pictures with your QUESTION, of your complete waffle maker. Lets see if we can figure out how to get it apart.
기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Vagelis outstanding:-)! Now measure the resistance on the bimetal switch. Blue and white wire. Let's see by how much it changes.
댓글 달기
귀하의 답변을 추가하세요
Vagelis 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 8
전체 시간: 75
