The Hoover Carpet Basics Power Scrub Deluxe Power Cleaner can be identified by its model number: FH50150. This upright power cleaner was originally released in 2014.
이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
Reviewed sidebar questions? There may be a belt drive, damaged or broken from a jam. A full parts diagram would help you determine if a belt drive is used or motor. If motor driven, checking for damage for overloading may require a multimeter to check for voltage to the motor.
F Dryer 의
