주요 콘텐츠로 건너뛰기
An update to HTC's original Vive, now with improved displays, sensors, and ergonomics. Released April 5, 2018.
Will your Vive Pro Headphone replacement part fit the Vive Pro2?
Hi, I have a Vive Pro 2 Headset and the left earphone is failing [sound stops playing on the left side]. Will your replacement part [Item # IF453-028-1 HTC Vive Pro Headphones] fit the Vive Pro 2 headset?
I have already removed the left earphone and verified that the contacts are clean. The sound is intermittent. I need a replacement part for the left earphone that has the volume control button.
Has anyone successfully used these replacement headphones on a Vive Pro 2 Headset?
Thank you,
Edward
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hey, Edward.
As long as you're capable of doing it yourself, I'd say it's fine to use a Vive Pro Headphone replacement on the Vive Pro-2. There is not too much differentiation between the two headphone parts, and certainly not enough difference to cause an issue. I hope you find this helpful.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Edward Leslie 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 176
