What the meaning of the 'normal' cycle button flashing indicates?
Any idea what the meaning of the 'normal' cycle button flashing indicates? Also when I press that button the cancel button will also flash. It will try to do a drain cycle but quits after a few seconds?
Update (12/01/2022)
So I disconnected power and the ribbon cable to the board. Reassembled and was able to run a normal cycle as it should work. All seems ok. Thanks for the help
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 4개:
Hi @justinweber3,
What is the model number of the dishwasher?
This is the Quiet Partner II. DUL240
Hi @justinweber3
Try resetting the dishwasher and check if that resolves the problem.
Here's a link that has worked for others.
Flashing Lights on Control Panel
Note : reading some of the comments below the answer, if it didn't work some had to try it more than once but then it did
Sure. I tried all that, cycling power and the reset. Didnt clear it out. Does anyone have a printout of error codes/diagnostic sheet so I can just get to the root of the problem possibly?
댓글 달기
