주요 콘텐츠로 건너뛰기
The Hoover LiNX is a cordless vacuum cleaner. The vacuum uses interchangeable fade-free lithium-ion batteries that allows this device to be used everywhere and on multiple floor types. The Hoover LiNX uses Hoovers WindTunnel® 3 Technology which uses three channels for suction to suck up debris.
turns on and quickly turns off
My Hoover LiNX coordless vac got caught on the end of a rug, did not catch anything in the blade, then turned off. When I turn it on again, after reviewing the rollers, etc, it turns on for quick second and then stops. Any idea what I can do to make my wonderful vac came back to life
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
If your Hoover LiNX cordless vacuum cleaner is turning on and then quickly turning off, there may be a problem with the motor or the power supply. Here are some things you can try to troubleshoot the issue:
  1. Check the power supply: Make sure that the vacuum is fully charged and that the power cord is securely connected to the vacuum and to a working outlet.
  2. Clean the filters: Over time, the filters in your vacuum can become clogged with dust and debris, which can restrict the flow of air and cause the motor to overheat. Clean or replace the filters according to the manufacturer's instructions.
  3. Check for obstruction: Carefully inspect the vacuum for any obstructions that may be blocking the air flow, such as tangled hair or debris. Remove any obstructions and try turning on the vacuum again.
  4. Check for damage: If your vacuum hit something or was dropped, there may be damage to the motor or other internal components. Inspect the vacuum for any visible damage and contact the manufacturer for further assistance if needed.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
This was happening to our machine. After inspecting the battery I discovered that the 'clip' on the bottom of the battery was stuck in the casing, there is a release button beside that clip, Press it in and the clip will pop out.
I believe that clip holds the battery in place. I'm not sure but suspect that is a safety feature to diconnect the battery if the motor heats up after you tangled the roller in the rug tassles. We had the same issue and it fixed the problem
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
RoseMary Cummings 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 3
지난 30일: 14
전체 시간: 807
