주요 콘텐츠로 건너뛰기
모델 A1051 / 4 또는 6GB 하드 드라이브
90 질문 전체 보기
se me quebro el encendido de mi iPod,
I broke on my iPod, then I can not turn on,.
how can I fix that part?. I could go and watch this because I conorm all the pieces just are not built like this .. please if not too much trouble .. thank you very much
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 2개
I don't think he has a iPod mini
Si es más facil para ud., puede escribir su pregunta en nuevo en español, con más detalles.
댓글 달기
답변 1개
선택된 답변
OK: If I understand right you broke your iPod Mini and want to fix it. First, what part did you break?
Go to : http://www.ifixit.com/iPod-Parts/iPod-Mi... and find the part you broke. Order it and then go to: iPod Mini and select the guide on how to replace the part.
If you can not find the part you broke at the site above you can try the following:
http://www.digiexpress.us/iPod-Mini_c_3....
But you should be able to use one of the guides listed above to install it.
If you want someone to just repair it, try: http://store.ifixiPodsfast.com/iPod-scre...
Be sure to get estimate first. Good luck
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
juan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 630
