주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Envy 15t 노트북은 디스플레이 하단 베젤 중앙에 소문자 “HP” 로고가 있습니다.
Blue screen of death
Hello I was using my laptop with no problem since I got it so I tried updating windows and it was stuck on %100 so I restarted my laptop thinking everything would normal ones it's on but I got the blue screen instead with critical process died stop code , I have tried everything but nothing works resetting,startup repair, uninstall updates nothing works but when I try system restore I have to tick a little box on the disk I'm using but I don't have a mouse pointer to tick the box, please help me.
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
@vybzonline update which part of Windows? Update to what?
의 공유
@oldturkey03 I was updating the windows 10 because it was not up to date.
의 공유
댓글 달기
답변 2개
가장 유용한 답변
How to fix a Blue Screen of Death on a Windows PC
Uninstall incompatible software.
Run a memory checker.
Check for hard drive errors.
Remove non-essential peripherals.
Replace defective or incompatible expansion cards.
Run Setup Diag after a failed Windows update.
Perform a clean install.
Regards,
Will
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thank you for your reply
의 공유
댓글 달기
Hello I will suggest you the following.
  1. Use specialized BSOD repair software.
  2. Uninstall critical third-party programs.
  3. Run SFC.
  4. Check all drivers if any driver is outdated update driver.
  5. Backup your data and clean install Windows
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Abdul Malik Suraj 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 17
전체 시간: 395
