주요 콘텐츠로 건너뛰기
Apple의 메인스트림 2021년형 iPhone은 9월 24일에 출시되었으며 6.1인치 OLED 디스플레이, 듀얼 1200만 화소 카메라 시스템, 5가지 색상으로 제공됩니다. iPhone 12의 후속 제품입니다.
20 질문 전체 보기
Screen burn/ghost images on dark backgrounds.
Hi all, I've had a panicked message this morning from a customer. She had purchased a used iPhone 13 and has noticed that she can see "someone else's apps behind her screen". She forwarded a video but it's hard to make out.
When the screen is dark (not off) she can see faint app icons "behind her apps". I'm thinking screen burn but she is concerned that there is some sort of virus or malware.
Unsure of device age and previous usage as I haven't seen the phone yet.
Any advice would be greatly appreciated
Thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Hi
At the moment I think it’s safe to assume that it’s not malware, malware usually does much worse thing and malware is very rare on iPhones
Also burn in is quite uncommon on iPhones that have Original displays,more common on 3rd party displays but still quite uncommon
what I think the issue is most likely to be is a dislodged display connector
It could also be debris but I have seen this happen on iPhones and iPods when the ether the display is damaged, connector isn’t seated properly or the connection has debris and needs cleaned with isopropyl alcohol
Might be worth trying the above before replacing the anything ,it’s entirely up to you:-)
Hopefully this helps
Any questions please ask
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
Hi, after seeing the device I confirmed it was burn in for my customer.
Her initial message made it sound like she could see another, fully working set of apps behind her own when viewing on a dark background.
Upon inspection it was only 2 app icons (telegram and Viber) that were present and in the same location while using the device in various iOS functions.
Thanks for your help
@dangerw1ll
Your most welcome
Glad you got it all sorted out:-)
@dangerw1ll must’ve been a bargain basement screen was it? I’ve replaced phone screens for years and not seen one iphone with screen burn, only dreaded Samsung.
@strongbow
that’s exactly what I was thinking ,iv never seen it on a iPhone ,only ever Samsungs
댓글 달기
답변을 추가하세요
iRepair 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 16
전체 시간: 774
