Fully charged Robit vacuum turns off after 1-3 minutes
Hi! I'm pulling my hair out over here, this vacuum is not even a year old and it's already failing. I've done a bunch of trouble shooting which I'll lay out.
Issue:
- On a full charge (breathing green light becomes solid green, charging by directly plugging into the wall, bypassing the charge station. There is no damage to the charging cable and no issue with the wall outlet.)
- Robit operates normally for about 3 minutes before shutting off. No issues with suction or pathing.
- I can not turn it back on again, it acts as if the battery is dead. Normally when battery is low it attempts to dock itself, it does not do that. I flick the power switch off and then on again, press the power button, it will not turn on.
- Plug the Robit back into the wall, green breathing light turns solid after less than five minutes, indicating full charge. It turns on and operates for about 3 minutes before the issue reoccurs.
- I can also plug the charging cord into the vacuum for a split second, it turns on and operates for about 45 seconds before the issue reoccurs.
- It is not hot in my home, the shell/underside of the vacuum is not hot to the touch after operating.
My trouble shooting steps:
- Tested front bumper for obstructions
- Wiped all sensors with a dry paper towel, cleaned all moving wheels/sweepers of hair and other debris.
- Emptied dust collector and thoroughly cleaned the three filters, properly reassembled according to the instruction booklet diagrams
- Opened the battery compartment to see if there was any kind of visible defect with the battery.
I don't know the first thing about appliance repair, but I'm willing to learn! Here are some pictures of the vacuum.
Any ideas?
좋은 질문 입니까?
댓글 3개
@helpaaaa the great description given by you, lead me to believe it is a power issue vs a sensor issue. This could be an issue with the battery controller. I recognize it is only about a year old, but I would still change the battery first. If nothing else, it will give a known-well starting point for further troubleshooting.
oldturkey03 의
Thank you so much! I'll try it.
Robit Owner 의
@helpaaaa Li-Ion batteries are not as bad as we think they are. They are actually pretty safe, so no worries about that.
oldturkey03 의
