주요 콘텐츠로 건너뛰기
Released in January 2016, the Chromebook R 11 C738T is a Chromebook laptop with a 360 degree folding touchscreen.
does this chromebook hace a hard drive which can be replaced
hard drive for chromebook. does this chromebook have a hard drive which can be replaced
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Hi Wenfrey,
Assuming you've entered the correct device category for your question, then I'm afraid I have bad news for you; no, there is no separate hard drive that can be removed and replaced. From the device page itself:
Unfortunately for the repairability of this device, both the memory and flash storage are soldered directly to the motherboard.
Without specialized tools and expertise, us DIY-ers are out of luck with upgrading this laptop's storage. It can be done by experienced repair technicians, but it's a difficult process to unsolder those parts and even then you have to find a pin-compatible part with more storage that the system BIOS may or may not be able to handle.
So the short answer is, no, you can't replace the hard drive, sorry.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
It has a eMMC sodered on Solid stade drive, there are models with 16GB or 32GB disks. The latter one beeing a little bit more rare. But, it does have a SD-card slot that supports storage extension, but probably not the answer you're looking for.
I've been looking into a possible mother board swap that would work in the stock enclosure, or at least with some modification but i haven't come to find anything suitable yet since i live in the EU and customs for every motherboard that might be compatible (at least physical) gets more than economically viable to order from the US.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Wenfrey Dumas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 15
전체 시간: 641
