주요 콘텐츠로 건너뛰기
Part of Google's third generation of Pixel phones, the 3a is a budget-minded option with the same camera as Google's flagships. Available in Clearly White, Just Black, or Purple-ish. Released May 2019.
68 질문 전체 보기
Is proximity sensor changeable?
I bought Google pixel 3a with non-working proximity sensor. I wonder can I replace it by myself?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Hi Eugene,
Just a quick sanity check; you have removed your screen protector and cleaned the screen, right? Simple fix that worked for several people, but a lot of times it doesn't occur to folks.
댓글 달기
답변 3개
선택된 답변
Part available online. Cheap part to be honest and no soldering required as it’s on a ribbon with a fpc connector. Follow this guide for the front camera replacement to gain access to the proximity sensor.
https://youtu.be/h0TqoAPKOlY
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
In theory it should be replaceable if the fact replacement proximity sensors are being sold and that it's replaceable on the 3a XL. I'm having a bit of a hard time finding the replacement guide for this specific device, but if you're feeling confident in repairing it on your own then definitely document your process for the rest of us.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
hello if you have the part i can try and assist you on the repair step by step but you will need to provide an image of each step after the direction is given so i can further be precise with my help
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Eugene Becker 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 16
전체 시간: 266
