주요 콘텐츠로 건너뛰기
3세대 픽셀 휴대전화의 일부인 3a는 구글의 플래그십과 동일한 카메라를 탑재한 실속형 옵션입니다. 클리어 화이트, 저스트 블랙 또는 퍼플 색상으로 제공됩니다. 2019년 5월에 출시되었습니다.
질문 마감됨
Screen is black after replacement
I followed the iFixit guide to replace the screen. Initially the phone battery was fully drained. I removed the old broken display, connected the new one, charged the phone a little to test if the new screen is working and glued it. However, I didn't to a good job with the glueing and decided to take the screen off and reglue it without disconnecting from the motherboard. I didn't remove the battery either which was charged at about 20% at that point.
Now the screen is black and I can't see any apparent damage to the connector or pins.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
you may have either
1 damaged the screen cables during the process of taking the screen off again, or
2 blown the display out because you didn't disconnect the battery the 2nd time
이 답변이 도움이 되었나요?
점수 0
댓글 달기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 99
