Where can I find the PCV valve in my beetle?
I got steam coming out the oil cap and I have rough RPM
Update (12/26/2022)
VW Beetle 2.0L 1999
좋은 질문입니까?
VW Beetle 2.0L 1999
좋은 질문입니까?
Although a PCV valve is an inexpensive item to replace and would be worth trying as a first pass, the symptoms you describe can also be attributed to a much more serious issue, that of a blown head gasket. If the PCV valve doesn't fix the problem, you should probably check the compression and run a block check test as your next steps.
이 답변이 도움이 되었나요?
지난 24시간: 2
지난 7일: 3
지난 30일: 7
전체 시간: 475
