주요 콘텐츠로 건너뛰기
2009년 중반기 모델 A1278 / 2.26 or 2.53 GHz Core 2 Duo 프로세서 EMC 2326
745 질문 전체 보기
Can this system still be repaired or it is a throw away?
I will try to tell all the information I have:
I bought system off ebay for display spare parts, once I changed the display and I decided to test the logic board of the system and the following things happened
1) there is a 45w power supply green led
2) connecting the battery - it is recognized and recharged
3) by pressing the start button the system starts and after 2 seconds it turns off and after 2 seconds it turns on again, after that the system is started only that the display does not show anything it is black, I also tried connecting the external display - nothing
4) I measured the voltage on the components that appear to be in the screen power supply chain on the diagram, they are all at 0v
the motherboard is 820-2530
I want to know if the gpu is dead, if it is still repairable in the sense that I would use it without its screen - via DP cable with external monitor so I don't care that the notebook display doesn't work
Update (12/28/2022)
https://drive.google.com/drive/folders/1...
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 25개
do you have the boardview and schematics for it
@tech_ni yes how i can add them here ?
@Game FullHD i have them i was just asking if you did
@tech_ni yes i have , so what we can check to say if gpu is dead or no ? consider that now I can only connect the power supply , when the power supply is connected there is a green light but it does not start , probably because it is a 45w which is not enough so I now take the measurements in s5 state
@Game FullHD do you have 3v3 on pins 2,3,4 of the lvds connector
댓글 20개 더보기
댓글 달기
답변 1개
선택된 답변
U7200 fault .........
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
check r2852 for allsyspwrgood
댓글 달기
귀하의 답변을 추가하세요
Game FullHD 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 7
전체 시간: 138
