주요 콘텐츠로 건너뛰기
Cellular version of Apple's 2nd generation iPad Air. Model A1567.
85 질문 전체 보기
Why does my screen have random splotches of shiny after removing case
Recently I took the case off of my iPad and I saw some weird stuff that will come off, but if I run my finger over it it comes right back. I need some help because I don’t want to have to look at that every day.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Give some screen cleaner and a microfiber cloth a try to get it cleaned up, but it may just be that these markings are worn into the display.
Even cases with cushions around openings can cause wear since the case rubs against the device as it's being used. In which case the only way to get rid of the marks would be to replace the whole display assembly.
Microfiber Cleaning Cloths 이미지
상품
$3.99
iFixit Screen Saver 이미지
상품
iFixit Screen Saver
$9.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Try some screen cleaner and give it a good rub, or ipa if you can access any.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Simple “:” GD 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 38
