주요 콘텐츠로 건너뛰기
삼성 갤럭시 A10s는 삼성전자에서 개발한 안드로이드 스마트폰으로, 2019년 3월에 출시되었습니다.
Why is my wifi and bluetooth not working
Why is my wifi and bluetooth not working Why is my wifi and bluetooth not working
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 99
댓글 28개
Has the phone been dropped or damaged at all?
I did factory reset but still not working
I went in my hardware but my wifi and bluetooth are not listed in and its says unavoidable
What must I do
I'm having the same issue on my Samsung Galaxy Note 20 Ultra. After the new update, they both stopped working.
Check (verify) the time zone on your phone. I had this problem On the last update and resetting the TIMEZONE corrected the problem.
댓글 23개 더보기
댓글 달기
답변 29개
가장 유용한 답변
There could be several reasons why your WiFi and Bluetooth are not working on your Samsung Galaxy A10s. Here are a few things you can try to troubleshoot the issue:
  1. Restart your phone: Sometimes, a simple restart can fix minor software issues.
  2. Check if the WiFi and Bluetooth toggle switches are on: Go to Settings > Connections and make sure that the toggle switches for WiFi and Bluetooth are turned on.
  3. Check if the WiFi and Bluetooth chips are enabled: Go to Settings > About phone > Hardware information and make sure that the WiFi and Bluetooth chips are listed as enabled.
  4. Check if there are any software updates available: Go to Settings > Software update and install any available updates.
  5. Check if there are any issues with the router: If you're trying to connect to WiFi and it's not working, try connecting to a different WiFi network to see if the issue is with the router.
  6. Reset the network settings: Go to Settings > General management > Reset > Reset network settings. This will reset all the WiFi and Bluetooth connections on your phone.
  7. Factory reset your phone: If none of the above solutions work, you may have to perform a factory reset of your phone. Keep in mind that this will erase all the data on your phone, so be sure to back up your important files before doing this. To factory reset your phone, go to Settings > General management > Reset > Factory data reset.
이 답변이 도움이 되었나요?
점수 28
댓글 37개:
I did factory reset but it still doesnt wrk
Hi I did all but didn't work
After the last Samsung update my wifi and Bluetooth isn't working as well
Same for me, bluetooth and wifi can't be on. when I tried to open it it'll become off again.
Same here to me
댓글 32개 더보기
댓글 달기
الخلل في ايسي بلوتوث والحل استبدال الايسي او تسخينه راح يرجع الجهاز طبيعي
Google translate:
The fault is in the bluetooth eSee, and the solution is to replace the eSee or heat it up, and the device will return to normal
이 답변이 도움이 되었나요?
점수 10
댓글 10개:
how to replace the esee or heat it up?
Oh my gosh I did everything but still won't connect I'll just chill here and wait for the answer
I am facing the same problem. My Wifi and Bluetooth is no longer working. Is there any Samsung Technician ca help me fix this problem? Thankyou.
I am also facing this issues wifi and Bluetooth devices is not working plz tell me solve the solution plz
Even if I refractory doesn't work
댓글 5개 더보기
댓글 달기
If your WiFi and bluetooth not working it is because of Ic problem you have to change it
이 답변이 도움이 되었나요?
점수 7
댓글 2개:
I did perform factory reset but still the same. Help me out pls
How can we replace Or heat it where it is inside the phone?
댓글 달기
If you have WhatsApp installed. Try cleaning WhatsApp data or uninstall WhatsApp. It works fine for me. A10S
이 답변이 도움이 되었나요?
점수 4
댓글 4개:
It's a hardware issue. The phone's IC has a problem that's why the Bluetooth n WiFi don't work. The technician will demand approximately R250 to R350 to fix it.
No hardware issue this is new update issue.
Not an update issue. My phone has not received an update in years because it an old phone (Galaxy J5 prime). So it is a hardware issue-
My Samsung a10s have the same problem
댓글 달기
turn on bluetooth to connect to nearby devices
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
Still my phone doesn't want to open
댓글 달기
Reset your Wi-Fi router. The location of the reset button depends on what Wi-Fi router you are using but every Wi-Fi router has one.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Thank you, Anthony, but this is not a solution to problem.
댓글 달기
Why is my wife and Bluetooth working
이 답변이 도움이 되었나요?
점수 3
댓글 달기
Try to format your phone
이 답변이 도움이 되었나요?
점수 3
댓글 달기
Heat ic 300 ⁰c but how can i show the ic
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Well I will suggest to do the software update or system updated of your phone. Sometime outdated software version can also cause these kind of issue as well.
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
You can't update phone without WiFi
Even if I restart don't enable and not op6
I did restart but still is not working
댓글 달기
Its hardware issue my 2 devices one got resolved heating ic and second one had replaced ic MT6631N
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Wifi end blootot hospot
이 답변이 도움이 되었나요?
점수 2
댓글 달기
WiFi not opening
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Since the problem occurred with all users of this version of Samsung, this means that its function was stopped in the latest Samsung update.
댓글 달기
My wife and bluetooth are not working on my phone my phone is Samsung A10s
이 답변이 도움이 되었나요?
점수 1
댓글 달기
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Bluetooth 11
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
WiFi and Bluetooth connection is not working
댓글 달기
I have an S20+ and a WiFi 6 home network. I'm running the May 2023 update to OneUI 5.1.
Suddenly last night I was unable to connect to my home WiFi network. WiFi worked fine for all my other devices. I did lots of Google searches.... After trying all the obvious simple things (toggling Airplane Mode, Rebooting the phone, etc.), I looked in the S20+ Settings / Developer Options this morning and found "WiFi non-persistent MAC randomization" and turned it ON. WiFi almost instantly started working again on the phone.
I hope this helps others.
Cheers,
Scott.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My wifi and bloototh not working
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My wifi and Bluetooth malfunctioning since last 2 months
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Why my wife and bluetooth not working on network
이 답변이 도움이 되었나요?
점수 0
댓글 5개:
My bluetooth and wife are not working my phone is Samsung A10s
Me 2 my Samsung A10s is not working
Bluetooth, WiFi and hotshot won't connect
My wifi and bluetooth not working
My Wifi and Bluetooth is not working in Samsung s20+ and developer option is also turned off
댓글 달기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My wifi & bluetooth not working, I have samsung Fold 3… .I got sick of samsung, Im going to buy Honor magic v3
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Wifi Bluetooth not working why problem factory already but not solve
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Why Bluetooth say disconnected
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Answer me plz
댓글 달기
I do no but it's is in software complaint
이 답변이 도움이 되었나요?
점수 0
댓글 달기
How i can fixit
이 답변이 도움이 되었나요?
점수 0
댓글 달기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I don't no but I want to learn
이 답변이 도움이 되었나요?
점수 0
댓글 달기
f your Wi-Fi and Bluetooth aren't working, start by restarting your device and router, and check for simple issues like interference or drivers being outdated. If those don't work, try resetting your network settings, which will erase saved Wi-Fi passwords and Bluetooth pairings but can resolve connection problems. For persistent issues, consider updating your system or, as a last resort, performing a factory reset.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Yidnekachew 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 22
지난 7일: 163
지난 30일: 710
전체 시간: 77,240
