이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
Hi Katrina,
Can you rephrase your question? I don't understand what you're looking for here; I'm sure my initial thought of, "Welp, it's probably on the drain pump" isn't helpful.
Are you looking for the location of the drain pump? Where all the wiring harness is routed to? Please clarify.
Also, there are a LOT of different 110 series washers, so if you need an answer that's specific to your washer, we'll need the model number.
Hi Katrina,
Jerry Wheeler 의
