주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2694 질문 전체 보기
Why do randomly I lose control of the screen?
Every so often, usually once per day, I will be using my phone and it will, without my touching, swipe around and puch buttons on the keyboard and I will have absolutely no control and it has sent weird messages to my friends. This is the weirdest thing I have seen on a phone. This wasn't a problem before, but I cracked my screen and took it to a repair shop (my parents would let me repair it myself) and when I got it back this glitch started happening. Does anybody know what this is and what I can do? I am very confused.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Hello! I've experienced a similar issue like this. You might have tried a few of these things already so you don't have to follow the steps in order. Here's what I would recommend.
1.) While it may seem obvious or stupid, try cleaning the device with a damp, microfiber cloth. If you can't get ahold of one, a paper towel will do. Unplug the device, shut it down, and gently wipe. Based on your issue that likely won't solve it, but it's worth it for the following steps.
2.) If you don't have a screen protector, skip this step. However, if you do, carefully take it off. Repeat step 1 again but you likely won't need to be as particular with it.
3.) If you don't have a hard case, skip this step. Sometimes if you drop a phone in a hard case, the case will bend. This can affect the screen and cause further issues with the responsiveness of the display. Just taking off the case might do.
4.) Force Reset your device. Apple explains it fairly well here. Select whatever iOS version you're running. It can't be iOS 16.
5.) If the problem still continues, I can almost guarantee that your issue was caused by a bad repair job. If the job was rushed, improper seating of the display cable as well as a dozen other issues from faulty repair/parts can cause this. I would personally repair it myself, but if you can't in your current position, I would see if your parents can bring you back to the repair shop or another one available. While most technicians know what they're doing, it's entirely possible for a few negligent ones.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Dimitri Cooper 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 5
전체 시간: 67
