주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
Broken screen what do I need to replace? Glass or whole panel?
Hello!
I dropped my iPhone on the floor today and the screen broke. I can still use the iPhone but there are cracks on the whole screen.
I'm not sure what I need to replace, the whole panel or just the glass:
Here is a picture:
http://i43.tinypic.com/6syj6f.jpg
Thanks in advance :)
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 1개
If I cracked my iphone 6 screen and some of the glass is missing and I see some of the parts of the phone what will I have to replace ?
댓글 달기
답변 4개
가장 유용한 답변
Unfortunately, the iPhone 4's display assembly is fused together in manufacturing, so you have to replace it as one unit (any Ebay sellers who might try to say otherwise are trying to scam you). We sell the display assembly and have the guide to show you how to do it.
iPhone 4 (GSM/AT&T) Screen 이미지
상품
$24.99
해당 답변은 도움이 되었습니까?
점수 8
댓글 9개:
Just what I thought. When I buy this will all the connecttors etc include? I mean so I just need to open the phone up and replace it and not missing any part? Sorry for my english i'm Swedish.
Thank you so much for your help David!
It's not exactly the easiest job to do but with some patience and the right tools, it can be done. Read through the guide completely and make sure you keep all of the screws in order.
The whole unit that you order includes the top glass, LCD, digitizer, and frame. There are two connectors that fit perfectly onto the logic board.
Good luck.
Thank you so much!
This is a real iPhone 4 glass right?
I mean, will the screen look like a totally new iPhone 4 that's been bought from Apple? Same quality retina screen etc?
Yes it is real iPhone 4 glass. It will look and feel just like it was when you first got it :)
dont get me wrong some ebay users are scams but some are real. They are way cheaper and work. Just got mine in today for 40 bucks. Way cheaper then $150.
댓글 4개 더보기
댓글 달기
i dropped my iphone today and it is cracked on the inside is that the lcd that is cracked and if not can this be fixed ?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
How do I know I am getting the right version. My version is A1349. I ordered from another company and they sent the wrong one. The tabs do not line up.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I can still use my phone, but the glass is cracked.
Also before I cracked the glass, I notice the phone would not hold a charge, but if I turn the phone off for, maybe 5 minutes, the charge Icon will indicate 50% power available, where as three to five minutes ago it was down to only 17% power available. And the power increase without plugging the phone up to any charging device, what's the problem,thank.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I broke my iPad RCA . Was wondering if I can put regular glass in it
@tyrone30 For the broken glass, you need to replace the whole LCD screen. For the battery, it may be a bad battery or charging port.
댓글 달기
귀하의 답변을 추가하세요
gronko 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 55,268
