주요 콘텐츠로 건너뛰기
5G 스마트폰이 탑재된 Google Pixel 6a 수리 안내서 및 설명서입니다. 2022년 7월에 출시되었습니다.
20 질문 전체 보기
Can I skip the display adhesive?
I broke the screen on my P6a, and I have the fix kit coming; however, I am wondering if I can skip the display adhesive and just clip it in on the 6a, seeing there are clips to have serviceability (at the expense of the IP rating, which I threw out the window anyway by dropping it and will fully void doing the repair).
Has anyone done this without adhesive at the expense of the IP rating? Since I got the phone used, I trusted the IP rating like a fart anyway. It's gone now anyway.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Hi Nick,
Yes, you can certainly use it without the adhesive, keeping in mind if you drop it the screen will most likely pop off; you're already well aware of the waterproof aspect, but don't forget about dust, pocket lint, etc.
If you can pick up a full body phone cover locally on the cheap, that would be a good way to mitigate those issues until you can do the actual screen replacement and reseal it.
I've let my grandson use his iPhone X without adhesive temporarily while I waited for parts; the difference there is that iPhones have those Pentalobe mounting screws that do an excellent job of keeping the screen on even without adhesive.
But yeah, I personally would go ahead and use the phone without the glue if I was in your position, especially knowing it's only temporary.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Plus being a used phone the IP rating was already unreliable. About the only thing it keeps out once you taint it is dust. I'd be totally hesitant to trust a kid with fully voided liquid resistance, but on adult owned devices we know the phones need to be babied, even if it means hiding under a gutter on the phone.
Never, ever trust the IP rating is good if you were not the first owner unless you personally had it repaired by the manufacturer.
댓글 달기
답변을 추가하세요
Nick 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 16
전체 시간: 592
