주요 콘텐츠로 건너뛰기
The Xiaomi Redmi Note 8 is a mid-range smartphone by Xiaomi released October 2019. It has a 6.3" IPS LCD display, a 48 MP main camera, a rear-mounted fingerprint sensor, a 4000 mAh battery, and runs on a Snapdragon 665.
22 질문 전체 보기
Problem sound in my phone . Please help me
There is an earphone that appears on the screen, without installing the earphone. How do I remove that? It caused me sound problems
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi Med toaiba,
Most devices with a switched audio jack have the capability to detect when something is plugged into the jack in order to automatically switch the audio from the internal speaker to the audio jack.
You phone obviously thinks something is plugged in. I strongly suspect that cleaning your port will fix the problem; it's likely something is stuck inside it but you'll have to examine the port to find out what. It could be dust, pocket lint or any number of other things, including a broken off jack.
Check it carefully with a magnifying glass and a bright light. If you find anything, you can try cleaning it with some fine tip tweezers or a toothpick. Some 90% or higher concentration isopropyl alcohol may help if there's dirt or contamination. If you need to dig dirt or lint out, you may be able to take a small drill bit that will fit inside and twist it by hand to pull the junk out of the port.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Med toaiba 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 14
전체 시간: 72
