주요 콘텐츠로 건너뛰기
Repair guides and disassembly information for Microsoft's third-gen Surface Laptop, released in October of 2019.
Will it boot with a bad battery (from wall power)?
I have a SL3 and it will not turn on at all. I have tried to force start it with the keyboard, but to no avail. Would a dead battery keep it from booting entirely?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
It's possible. It depends on what's wrong with the battery. No power issues can be tricky because they can be caused by pretty much any part in the device. Or it could be the motherboard itself.
Does the light on your charger come on when you connect it to power?
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Sadly I only have a Surface Go Charger (no light) and USB-C chargers.
@dragon2236 Got it. That makes sense. In that case, it's going to be a bit trickier to determine what the issue is. We might need some history of the device to know more. What happened leading up to the device not powering on? If you know.
Otherwise, this will likely require opening up the device to know more. But battery would definitely be on the list of things that could be at fault.
댓글 달기
답변을 추가하세요
RandyDragon50@gmail.com 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 9
전체 시간: 203
