주요 콘텐츠로 건너뛰기
2세대 iPhone. Model A1241 / 8 또는 16GB 용량 / 검정 또는 흰색 플라스틱 뒷면. 첫 번째 iPhone보다 수리는 더 간단하며 스크루드라이버, 비집는 도구 그리고 흡입 도구가 필요합니다.
1158 질문 전체 보기
dropped in water, what to do?
dropped i phone in water, had protective case on. Seems to be OK except that when I place a call and receive a call I cannot hear anything, the mute is NOT on. Have it turned off and siting in a bag of rice. thoughts????
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 3개
가장 유용한 답변
DONT TURN IT ON FOR A FEW DAYS. leave it in the bag of rice and power it back on in a few days. If you still have problems you might need to replace the speaker assembly. Search this forum for "water damage" or "liquid spill", you'll find dozens of threads with helpful ideas.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
It is important to not turn on electronics after it has touched water. However if you want a different item than rice to tuck your electronics in you can try the Thirsty Bag.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Before you do anything insure that the device is completely powered down!
Go to the grocery store and buy the zip lock bags for the freezer that you can vacuum the air out(it works with water too). Place your iPhone or other electronic device inside and add rice too(it will capture the water as it is drawn out of the device). Now close the bag and start using the vacuum. Go back periodically and use the vacuum more. Two or three days later remove the device from the bag and gently warm the device(no more than 100 degrees). After a day of that you device should work. If not sell it to a repair shop and buy another one.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Amy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 5
전체 시간: 3,640
