주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
iPhone 6S is stuck on battery screen
This iPhone 6S hasn't gotten used yet, So I plugged it in.. And it was charging!
So I checked Apple Music on my Mac, and it wasn't showing up after 2 hours of charging.
Its not hot, It's cold, and I tried multiple lightning connectors.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
To anyone who has this problem, I solved it!
Use DFU mode! To activate, follow my steps:
1. Press and hold the power button and the home button for 10 seconds.
2. After that, still press the home button for 10 more seconds.
3. Release the home button after step two, and you're screen will go black.
4. A window will pop up saying that an iPhone has entered DFU mode.
5. You're done after you reinstall the software.
"Is DFU mode the same as recovery mode?"
No, DFU mode isn't the same as recovery mode. In DFU mode, the device is still powered on but the screen is black to signify that it is in DFU mode.
Recovery mode is different, that is when a device is water damaged, boot looping or more. You use recovery mode when a device actually shows up in iTunes, now replaced by Apple Music. Recovery mode can also be used when there is a system issue with the device.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ionlyfixsoftware 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 41
