주요 콘텐츠로 건너뛰기
Cellular version of Apple's 2nd generation iPad Air. Model A1567.
85 질문 전체 보기
Will it run without the battery?
The battery is dead. It powers down within a minute or two after I unplug it. I'm concerned that the battery could develop issues, since it's dead and under charge 100% of the time.
Can I just pull the battery from it and reassemble it? I only use it plugged in at the moment. I realize it sounds weird, but it's an old iPad. (It's in the 'old folks home' part of its life) I really don't see using it seriously as a battery powered iPad depending on the battery, so why replace it. I just want it to be 'safe' if the battery decides to swell or overrun. In other words, I can't afford to replace it, and see no need to replace the battery, but would like to keep it working. Long question, I know...
Thanks...
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
No, it needs the battery. Easiest way is just to order a cheap battery to replace the one in it since you plan on opening anyway.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
100% can confirm. These will not boot all the way most of the time without an installed battery.
댓글 달기
귀하의 답변을 추가하세요
RobCow 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 56
전체 시간: 236
