Monitor is off after lightning
Wanna fix the monitor that wrnnt off after over voltage
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 5개:
Can you disassemble the monitor, then upload pictures of the circuit boards? 기존 질문에 이미지 추가하기
의 공유
jackmotimele104 are you saying that the monitor does not want to turn off? It is on all the time?
의 공유
Did you try another External Power Supply?
의 공유
I'm having the same issue with what looks like almost the same exact monitor: LG 27GL650F-B. Seems like a power surge happened even though I have a surge protector because the monitor flickered, then shut off, and hasn't been able to turn back on since. What tools do I need to fix this and does anyone know how?
의 공유
@ryanarther if anything it'll most likely be the power board. You will have to disassemble your monitor and check the board. As for tools, commonly just a few hand tools (screwdriver set) will do. You may need more once you know what is wrong with it, but for now, just disassemble and evaluate.
의 공유
댓글 달기
