주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
old water damaged iPhone with power issues - anyway to recover data?
i have an iphone 5s that overheated in 2019 and died completely, which was later submerged in water for about half a day and smashed (stupidly), is there any chance whatsoever of recovering the data off the board? the phone in a new housing, battery, display, etc just warms the battery like it did before it was water damaged, is it a lost cause?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
probably not. once the phone innards get wet, your worst enemy is time. the quicker you can get it dried, the better. the longer the liquid sits, especially in a closed phone, the greater the damage from corrosion.
here's what i recommend. get the motherboard out and give it a good 1+ day soak in 99%+ isopropyl alcohol (IPA). if you see any visible residue or corrosion, give it a very gentle scrub with a very soft tooth brush (like the kind dentists give free to young kids). after the scrub, give it another soak (at least half a day this time) in clean IPA. agitate a little then take it out and give it one final rinse with clean IPA. bend a paperclip open and pop one end through an open hole so you can hang it to dry in a slightly (or much) warmer room than usual room temperature. make sure the humidity is as low or lower than normal (ie, using a hot shower to raise the air temperature of the bathroom would defeat the purpose - i know this should be obvious, but sometimes ya just gotta say it). let it air dry for at least a day or two.
at this point, if you have known working and dry parts, you can reassemble and give it a shot. i'd be hesitant to use the original parts because of both the liquid and physical damage.
at this point it's a crap shoot. if the board is dead, no amount of IPA will resurrect it. but i have used this method to bring motherboards back to life than had suffered major liquid damage.
good luck to you
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
yeah, thanks for confirming what i had feared. oh well, i will now backup my phone and be more careful next time
댓글 달기
귀하의 답변을 추가하세요
bit 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 34
