주요 콘텐츠로 건너뛰기
LED bulbs have started flickering and turning extremely dim instantly
We have a T8 fixture over our kitchen sink. We have been using LED bulbs compatible with T8 for years, They generally last nearly a year before needing to be replaced, but the most recent one started flickering after only a few months of use and went out completely a week ago. Since then we have replaced that bulb with two others, both of which started flickering almost immediately, and then after about a minute went exceptionally dim. This change is accompanied by a strong chemical odor (I'm assuming it's something happening to the phosporous inside the light).
Is this a common issue that is fairly easy to diagnose and fix on my own or will I need an actual professional to look into it?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi Nathan,
Okay, let's start out with a clarification. LED replacements for fluorescent bulbs do not contain phosphorus. Fluorescent bulbs work by running high voltage through mercury gas, which produces ultraviolet light. Of course, that doesn't help light up your house, so they coat the inside of the glass with phosphorous, which glows white when exposed to ultraviolet light.
LED bulbs don't need that conversion, so there's no need for the phosphorous.
Regarding your actual problem, fluorescent fixtures are pretty simple devices. They really only have two parts; a ballast that boosts the line voltage up to anywhere from 300 to 900 volts to start the current flow in the tube, then drops back down to anywhere from 100 to 175 volts once the current flow has started.
So really, since you've replaced your fluorescent bulbs with LEDs, the only part left that could be giving you trouble is the ballast.
At this point, assuming you have a bad ballast, you have two options. First, you can try and locate a replacement ballast, which is probably feasible; places like Home Depot do sell them.
The other choice is to eliminate the ballast completely. LED replacement bulbs come in two styles; ones that are compatible with a ballast, and ones that simply run on straight line voltage. The second style requires you to rewire your fixture to take out the ballast and wire the power directly to the bulb connections rather than going through the ballast.
So you can replace the ballast and keep your existing bulbs (assuming they still work and haven't been damaged by the faulty ballast), or you can replace your bulbs and eliminate the ballast.
I had exactly the same situation in my house; I bought a ballast that looked like it was compatible, but apparently it wasn't because it burned up. Oops. I ended up just buying a whole new fixture because it was cheaper than replacing my bulbs, but your mileage may vary.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
nathan.verbois 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 50
전체 시간: 1,258
