주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2020년 4월에 발표 및 출시된 2세대 iPhone SE의 수리 및 분해 정보입니다.
How can I fix NFC?
Hi!
I think the NFC of my phone is broken : I use it for Apple Pay and to check my glucose (freestyle libre sensor) and it doesn't work for two days …
I have some questions :
- Is there something else to check or to change except the antenna?
- Where can I find a repair guide to do it?
Thanks+++
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개:
What troubleshooting steps have you followed so far? Have you attempted to power cycle the device?
댓글 달기
답변 1개
Hello Camcam,
the NFC loop is built identically to the model 8. The important thing is why it stopped working. Immediately before noticing that NFC is not working, did your phone have a fall or similar incident? All this, from the point of view of diagnostics, is important and speeds up the whole process.
The antenna problem never occurs by itself. It is usually related to a fall or wather damage. In fact, all you can do (assuming you have experience with a screwdriver) is to remove the screen and check the continuity of the antenna line from the motherboard to the internal antenna at the top of the housing. In case of an incorrect reading, you can replace the 1-st step antenna. The cost is about $2-5 if you decide to do it yourself. On the other hand, you can test ApplePay in store when paying before and after factory resetting your phone. Sometimes it happens that NFC communication hangs the entire subsystem due to compatibility problems with various devices in this technology. The third and final option is to find a good repair shop where the technician "took his teeth" (or "ate his teeth" - people say that in my location) on repairing the motherboard of Apple devices. You're sure to find a few of these places depending on your location.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
My iPhone SE is having the same issue, is there a picture anywhere of the NFC antenna and what contacts to check?
I'm sure you'll find one somewhere online.
댓글 달기
답변을 추가하세요
Camcam 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 48
전체 시간: 3,928
