주요 콘텐츠로 건너뛰기
9월 20일에 출시된 가장 크고 비싼 2019년 Apple 스마트폰으로 6.5" OLED 디스플레이를, 트리플-렌즈 카메라 시스템및 크게 향상된 배터리 수명이 특징입니다. iPhone XS Max의 후속 제품입니다.
165 질문 전체 보기
Oled screen replacement and update
Is it okay to update even i have installed non oem screen to my phone? Because i have seen many issues that some users reported they have non oem screen replacement and then an issue appear after updating there iphone
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
It depends on the type of screen replacement you have installed. If the replacement screen is compatible with your phone model and the manufacturer has ensured that it is compatible with the latest software updates, then it should be okay to update your phone.
However, if the replacement screen is not an OEM (original equipment manufacturer) screen and has not been tested to be compatible with the latest software updates, then updating your phone may cause issues such as compatibility problems or even permanent damage.
In general, it is always best to use OEM parts when repairing or upgrading your phone to ensure compatibility and minimize the risk of issues. If you are unsure about the compatibility of your replacement screen, it may be best to consult a professional technician or the manufacturer of the replacement screen before updating your phone.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Kristian Vincent Mabalot 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 84
