주요 콘텐츠로 건너뛰기
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
20 질문 전체 보기
"Whea uncorrectable error" blue screen
Hello, I changed the processor of my pc and I also put a new graphics card in it, and when i play any game (Fifa 23, Valorant, Tomb Raider, Fall Guys, etc) it crashes and restarts itself or the error "whea uncorrectable error" appears.
I tried formatting the pc from 0, downloading the latest version of drivers and bios, verifying that everything is well connected, etc.  I also tried changing the power cable of the power supply, and it keeps happening.
Then, I changed the processor to the old one, leaving the graphics card, and it worked fine, but when I reinstalled the new one, the error appeared again.
Can someone help me?
PC specs:
Ryzen 5 5600 (the previous one was a ryzen 5 3400g) - MSI Rtx 3050 gaming x - 2 x 8 gb 3200mhz - B450m ds3h gigabyte - power supply of 650w 80+ bronze - SSD 240gb - HDD 500gb
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Two things spring to mind. And maybe you've done this already, but have you tried clearing the CMOS between the two CPUs? I would even go so far as to remove the little button cell battery rather than just using the jumpers.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
no, I didn't do that, but I took the pc to a computer technician and he told me that he didn't get the error and it worked fine. Later, I tried it in another house and it worked fine. I don't think it's a computer problem. What should I buy to fix it? I also tried with voltage stabilizer and it didn't work.
댓글 달기
답변을 추가하세요
Felipe García Kralj 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 307
