주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Linksys Velop WHW01 is a Mesh Wi-Fi System designed to fit anywhere. The design features intelligent mesh technology, and a sleek, modular design.
Why is my linksys whw01 not resetting?
I follow all the step to reset to factory mode , pushing button 30 secs, not working, have tried turning it off and back on and nothing. Light is always fixed blue
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
You must wait until the router fully reboots after resetting. This can take up to 10 minutes. I know one would expect that once the "reset" happens and the LED goes through the reset sequence, that the router would be reset. But that is not the case, after the reset sequence (fading in pulses then bright red) the router must completely reboot (load the firmware) before the reset is complete. Any interruption before full reboot will negate the reset.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
The steady blue light that does not blink or change color in response to the reset button or a power cycle seems to be a fault condition.
The manual states to hold the reset for 10+ seconds. Nothing happens.
Elsewhere on the web people describe needing to give it more time, but those suggestions are in response to a unit rebooting - my constant blue light system does not reboot or change in any way when the reset buttons is hit.
I notice the blue light is slightly less bright than a working node - so I tried a different , known working power supplies with no change.
Finally, the unresponsive unit does not broadcast any SSID, and when connected via Ethernet, does not register.
I think it is dead, Jim.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Confirmed.
I determined that the nodes are reaching end of life or a firmware update is corrupting the device. I purchased a few additional units as refurbished and one of them is also showing the same issue after using it for 2 months, so I purchased an entirely new mesh system that works way faster.
Bottom line, if a Linksys node is not connecting and not resetting it's dead. Even the one I was able to reset didn't stay in service for more than a day.
Disabling Auto update didn't seem to prevent the update.
댓글 달기
I agree Glenn @glenn73737 I observed similarly on my device too! Thanks Glenn
Further to Glenn's answer I thought to share the guide for Linksys Velop WHW01 here for the benefit of other users finding your answer online.
Linksys Velop WHW01/VLP01 User Guide
  • refer to page 34 - How to restore factory defaults
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Maria 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 82
전체 시간: 3,479
