Charging problems on iPhone 6s
Greetings all. I have a problem with charging my iPhone 6s. Last year it started giving me problems and I replaced the battery (it was due for a replacement anyway) thinking it would solve the issue only to find out it didn’t solve the problem. I then inserted a piece of rubber on top of the connectors (battery & lighting assembly connector) that did the trick. My phone worked fine until about 2 weeks back when it fell 3 times in a single week then the problem started again.
What is actually happening is that I have to press down (using my finger) the components on the inside. It could be the battery connector, sometimes when I press down the speaker as well, sometimes I just touch the small black wire with a gold head (apparently it’s an antenna) or sometimes the flexi cable that gives the logic board power from the lightning connector. It is never the same place,the charging port doesn’t yield any results I only get a reaction when I touch the components on the picture (NOTE: the picture uploaded is that of a different phone I just used it so to try & indicate what I’m talking about).
That leads me to believe there is nothing wrong with the charging port. Someone recommended I get a new lightning connector assembly but I’m a bit skeptical.
Does anyone have an idea on what the problem could be?
Tried different charger, cleaned the port, made sure the battery is properly plugged in on the logic board. I have tried everything recommended except buying a new lightning connector assembly.
In order for the phone to charge properly now I have to clamp the screen with a paper clip, the paper clip is placed on the side of the phone just above the speaker. Sometimes charging it has the opposite effect, meaning it drains the battery instead of filling it up.
Hope this makes sense
좋은 질문 입니까?
