Second Screen not Connecting
I have purchased a dual screen but somehow cannot connect to the main screen.
좋은 질문입니까?
좋은 질문입니까?
Same thing here...
I Bought a second screen, due to the repair bill being almost as much. That Second screen works...
Hint:
Connect it ( second screen) to the V60, then Don't continuously connect and disconnect.... Get the little external USB adapter and charge thru that
NO excuses ... Don't make my mistake. Once working, don't disconnect it, unless you can do as I will (am) doing in the last paragraph...
Seems there is a particularly delicate connection issue between the V60 unit's connecter, and the screen.
Also the V60, even without the dual screen, will fail to charge with adequate speed due to the phone's connector..
I'm purchasing a kit to clean all the above connectors. Someone indicated this is an issue with the phone's charging port, or maybe the dual screen's port. The iPhone has the same problems.
이 답변이 도움이 되었나요?
This worked for me
지난 24시간: 0
지난 7일: 2
지난 30일: 26
전체 시간: 911
Treve Dyoll what kind of dual screen? How are you planning on connecting that to the device you selected LG V60 ThinQ? Post some pictures of exactly what you purchased. We need a make/model etc. 기존 질문에 이미지 추가하기
oldturkey03 의 공유
My dual screen v60 thin Q screen not come on in the case
Aaron Tingle 의 공유
