주요 콘텐츠로 건너뛰기
Apple의 2020년 주력 iPhone은 10월 23일에 6.1" OLED 디스플레이, 듀얼 12MP 카메라 시스템, 그리고 다석 가지 색상으로 출시되었습니다. iPhone 11의 후속 제품입니다.
My face id does not work after replacing the backglass
Recently i have replaced the back glass of my iPhone 12 as far as I know face id should not be affected by it but still it doesn’t work. It did work before the replacement.
Update (02/21/2023)
O have on of those heat tables so i can remove the back glass a bit easier.
when i want to do the face id it says that it is not available
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
Hi furkan,
So what method did you use to remove the back glass? Heat gun? That's the most common way for us home DIY-ers to do it. The downside is that there are a lot of components on the other side of that sheet of metal the glass is mounted on, and it's not at all uncommon for those components to get damaged as a result of the heat used.
By far the safest way to do a glass replacement is to basically gut the phone before starting so you don't get heat damage on any of the components; of course once you've gotten to that point you might as well just buy a replacement housing. The use of a laser to burn off the adhesive is what the professional repair shops use, as it doesn't transfer much heat to the inside of the phone, but that's not something most of us have access to.
Can you be a bit more specific on what isn't working with your Face ID? Is it not available, or it's telling you to move a little closer/further away, or what?
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
I am having the same issue, because I did a back glass on a 13 mini however now the phone says Position your face within the frame.
It’s not available
@miskaylaxjames Generally that particular error is related to the front camera. Did you also do a back glass replacement? It's possible you overheated the flex cable on the selfie camera causing damage. Does the camera work otherwise?
댓글 달기
Open the phone and remove the front camera, Face ID module and check you haven’t damaged the ribbons.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Mine too is showing Face ID is not available
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
furkan F. 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 734
