주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz) 또는 2.5 (Turbo Boost 최대 3.7GHz) GHz 쿼드-코어 Intel Core i7 프로세서.
467 질문 전체 보기
MacBook Pro not starting up
Replaced the battery. Followed the directions carefully. After putting the computer back together I started the machine and received the question mark. I went through the disk utility and noticed the drive was not showing up. The disk utility is not showing the disk either. What would be the next step diagnosis to approach? Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
As you are getting the looking for the OS symbol (blinking question mark) the drive is not recognized. Is this the original drive or did it get swapped out?
If it’s what the system had then it’s possible the socket got damaged or the contacts are not making a good connection.
If this is a different drive then it’s either just a simple correction as the expected drive is not present (or the setting got lost). Restart your system pressing the Option key to get to the Startup Drive manager, then select the boot drive.
If that fails then you have a newer file system on the drive than what the system can support as the systems firmware was not updated to support APFS from the older HFS+ file system. Using Bootable OS installer with Mojave or newer, no higher than macOS Big Sur (macOS 11). So you can upgrade the systems firmware and refresh the OS.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Mark McKay 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 21
