주요 콘텐츠로 건너뛰기
2.3L 4cyl or 3.0L V6, 6th Generation
430 질문 전체 보기
Does it make a difference if the battery and starter is on opposite si
I went to get a starter at pick and pull and the car was exactly like mine but battery and starter was on passenger side of the car and mine is on driver side does that make a difference?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi Librada,
It might make a difference; your Honda came with either a 4 cylinder or a 6 cylinder engine, and it's quite likely the two different engines use different starters.
If you post the year and engine size of your Accord, we can try and look up the specifics of whether the two engines use the same starter or not.
UPDATE:
The only explanation I can come up with for what you're seeing is that the one you're looking at in the Pick 'n' Pull is a four cylinder while yours is a six. Here's a 2.4L from 1998 to 2002, showing the battery on the passenger side.
While a picture of another 2002 with a V6 like yours shows the battery on the driver's side like this.
Assuming that's what's going on, then it's a no go on the starter. The 4 cylinder takes a starter that looks like this.
While the one for your car, the V6, looks like this one.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
My car is a 2002 Honda accord v6 engine the vehicle was exactly like mine but on different side than mine it was at pick and pull
댓글 달기
귀하의 답변을 추가하세요
Librada Barreras 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 15
전체 시간: 55
