주요 콘텐츠로 건너뛰기
Netbooks도 수리가 필요합니다, 자사의 안내서를 사용하여 계속 사용할 수 있도록 하십시오.
How to remove windows ce 6.0 from prixton netbook smart p1282ga?
Hello! i would like to remove windows ce 6.0 from prixton netbook smart p1282ga any advices on how to do it ? and which operating system should i install?
any help would be very appreciated.
thank you!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
To remove Windows CE 6.0 from your Prixton Netbook Smart P1282GA and install a different operating system, you will need to perform a complete reinstallation of the operating system. Here are the general steps you can follow:
  1. Download a new operating system that is compatible with your netbook. Make sure to choose an operating system that is designed for netbooks with similar specifications to your Prixton Netbook Smart P1282GA.
  2. Create a bootable USB drive or DVD with the new operating system. You can use software like Rufus or UNetbootin to create a bootable USB drive.
  3. Insert the bootable USB drive or DVD into your netbook and restart the device.
  4. Press the key that takes you to the BIOS settings. This key varies depending on the netbook's model, but it is usually F2, F10, or Del.
  5. In the BIOS settings, change the boot order to prioritize the USB or DVD drive.
  6. Save the changes and exit the BIOS settings.
  7. Follow the on-screen instructions to install the new operating system. You may need to format the hard drive before installing the new OS.
  8. Once the new operating system is installed, restart your netbook and remove the bootable USB or DVD.
  9. Install any necessary drivers and updates for the new operating system.
It's important to note that removing the original operating system from your netbook may void any warranty or support from the manufacturer. Also, make sure to backup any important data before proceeding with the installation.
As for which operating system to install, it depends on your preferences and the netbook's specifications. Some popular options for netbooks include Windows 10, Linux-based operating systems like Ubuntu or Chrome OS, or lightweight versions of Windows like Windows 10 S or Windows 10 LTSC. Make sure to choose an operating system that is compatible with your netbook's hardware and meets your needs.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
thank you very much for your help!
I have made the first three steps but I have no clue how to enter the bios settings, no key is working any suggestions ?!
here are the specifications of the prixton netbook:
Single-core 32-bit ARM9 processor
128MB of RAM
Hard drive with a total capacity of 2GB
SD/MMC card reader up to 8GB
Windows CE as default pre-installed operating system.
thank you!
댓글 달기
답변을 추가하세요
SAME 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 5
전체 시간: 194
