주요 콘텐츠로 건너뛰기
Apple이 2019년 3월에 출시한 새로운 iPad Air 태블릿, A12 Bionic 프로세서와 10.5" 스크린을 자랑합니다.
35 질문 전체 보기
iPad Not Powering on - Charger weird readings
Hello everyone.
My iPad Air 3 stopped working. I then found out that the display was defective and replaced it. After that, it fully boots up once. I let it charge to about 80% and then turned it off. Now it doesn't work anymore. When I plug it into the charger it shows 5V and rises to 2.2A charging power and then drops to 2V and 0A only to then rise again to 5V 2.2A. This repeats itself endlessly.
No Apple logo or anything like that appears on the display. I've already tried a reset via power + home button.
Board looks clean so far, nothing gets hot when the charger is on.
Any tips ?
Thanks and Greetings
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
If the charger drops to 2v then I'd try another charger. Should be constant 5v at least.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
kilkenny91 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 12
