주요 콘텐츠로 건너뛰기
The Acer Spin 5 is a mid-range laptop with a 15.6-inch display. The Spin 5’s display can rotate nearly 360 degrees around the base of the computer, which makes it very versatile for various applications. Our research has not indicated any major recurring issues with this device or any manufacturer recalls since its release.
2 질문 전체 보기
Why is my laptop on switching on?
my laptop went off whiles i was using it and never switch on
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Did you tried replacing the battery? It can be an issue with your laptops logic board or it can be a faulty connector or a battery. Try opening it up and checking on the battery connector’s condition or any corrosion on the motherboard.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Draphor knowledge kwame 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 45
