주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
BeatsX 무선 인이어 헤드폰은 2017년 Beats by Dre에서 설계 및 제조했습니다.
Won’t turn on and can’t reset
My Beats X won’t turn in and I can not reset it
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 2개
가장 유용한 답변
From what I learned it's all obviously caused by a faulty battery.
I actually found this guide on reviving a battery in Beats X.
If that doesn't work - here's a guide on replacing a battery and those guys offer a place to buy a new battery as well.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Basically your battery is dead and needs to be replaced. I had the same issue with my Beats X in-ear headphones.
My Beats X were also 5 years old and I hadn't used them in more than six months, which probably made things worse and allowed the Li-ion battery to discharge completely.
I tried these options before confirming the battery was dead and needed to be replaced:
  1. I charged my Beats X overnight for more than 12 hours.
  2. I attempted a factory hard reset by plugging in the lightning cable to the charging port and then holding down the power button + volume down button at the same time, for 10 seconds or longer.
There was NO LED flashing after the factory reset. I removed the lightning charging cable and holding down the power button didn't start up my Beats X. After plugging in the lightning charging cable, the LED would flash white/ red/ white/ red and then stay on white.
Helpful Resources & Guides:
  • This place sells new aftermarket replacement batteries($14.49 each); and offers a good written replacement guide.
I hope this helps!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Glenn 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 81
전체 시간: 2,492
